Hey I was interested in a ev conversion using a prius motor and controller with drop in board by evbmw.com. Also check out damien magiures channel, he does great builds with reused ev tech.
I was interested in toyota/prius parts because far better OEM quality and cheaper than any new motor i could find online.
I put all the info resources I had found in this thread.
Hi all Starting a thread to collect all available info on the 3rd Gen Prius transaxle in one place. If you have any info, links, documents etc please post here. Prius Gen 3 wikipedia page Prius Gen 3 workshop manual, pdf 7595 pages, outline links to different areas/topics OEM guide on how to...
www.diyelectriccar.com
A single 60-80kw prius motor would be a little under powered for a motorhome i guess, could work with correct gearing. Or just use two of the transaxles, they are quite cheap.
As said highlander transaxle even better, less available though.
