G
Guest
·I have been working on my MG EV and finally dug out a problem. The issue was with the throttle cutting out and causing a fault. It was happening with the PB6 and my Evnetics throttle. What is happening is a throttle out of bounds fault. In other words I am moving my throttle too far for the settings and with the PB6 I was getting a cutout on the low end and high end. Now that I know the issue I should be able to adjust out the issues. Will report tomorrow. It will be an excellent new year. Starting out great. Lithium pack should be installed in the next few days. Been weeding out this problem before I switch the lead out. Now to adjust the problem out and then do a battery change.
Pete
No issue with the throttle like I had thought with the PB6. Better with the Evnetics throttle but still needs finer adjustments.
Pete
