I'm a bit slow in getting this build thread started seeing as how it's been in-process for more than 5 months now. But like they say, better late than never!
So here are some of the basics on the build.
- It's a 1975 BMW 2002. The ICE was pretty tired with more than 250k miles on it.
- I decided to have RebirthAuto do the actual conversion because if it was left to me, it would take 2+ years to get road worthy.
- We are keeping the 4-speed manual transmission and Rebirth has made an adapter from a single block of aluminum to mate the transmission and the Warp9 motor through the stock clutch/pressure plate.
- Power will come from 11 Deka Deep Cycle GEL 12VDC 97.6AH Batteries. 8 will be mounted in the trunk and 3 in the engine compartment along with a service battery.
- Controller is a Soliton1 with liquid cooling running through a heat exchanger to keep everything cool.
- Air conditioning is supplied through a GM compressor mounted to the front of the Warp9 with a custom mount made by Rebirth.
- Monitoring/instrumentation will be via PakTrakr.
- DC/DC converter was originally planned to be Kelly Controls but I believe that has since changed. (I'll update once I know the specs)
- Battery charger was also originally planned to be a Kelly but that has also changed. (I'll update once I know the specs)
I'll post progress pictures as it moves along.
