Why propane? It is expensive and made from oil like gasoline or from natural gas. Do you want a ICE backup on a normally electric powered vehicle?
yes, i do want ICE back up due to range needs. i want propane or NG over gasoline due to emissions issues. i was checking propane prices and it's cheaper than gasoline.Why propane? It is expensive and made from oil like gasoline or from natural gas. Do you want a ICE backup on a normally electric powered vehicle?
i dunno, that's why i'm asking you smart-guysWhat are the other options?
i'm hoping folks can provide some insight.
see, with my job, i don't have a standard commute to work. i'm a social worker. i do home visits all over wayne county, where detroit is located. some days i travel less than 10 miles, which would be perfect for an EV. other days i intend to travel just 10 miles and i get a call and need to see a client with little warning and travel 100 miles. a trailer would be rad, except it'd be difficult to pull a trailer into some of the neighborhoods that i travel in, because of safety issues.Sorry, my question was directed toward "atzi" as he questioned the idea but didn't offer a solution. I also am thinking about a hybrid option (add on a generator trailer to extend range when driving further than the daily commute)...
I guess you are referring to where I asked ......Sorry, my question was directed toward "atzi" as he questioned the idea but didn't offer a solution. I also am thinking about a hybrid option (add on a generator trailer to extend range when driving further than the daily commute)...
Little bit I know about natural gas and propane.........................yes, i do want ICE back up due to range needs. i want propane or NG over gasoline due to emissions issues. i was checking propane prices and it's cheaper than gasoline.
i can't afford the $15k to put in enough battery capacity to justify spending upfront costs on a conversion. likewise, i can't afford any of the new production EV's or hybrids.
for me, the idea of loading up on 30 pounds of propane to augment distance is pretty much awesome. considering low carbon emissions when a generator kicks in, makes the prospect that much more attractive.
think chevy volt, except clean burning propane.
I remember in the mid 1980's I worked as an automotive mechanic for a shop where we repaired our town's utility vehicles.
Jackson, TN
These vehicles had been converted to run on natural gas. One truck I repaired ran on propane. The conversion was an outfit that sprayed in through the carburetor's top where the breather goes. The more vacuum the engine produced, the more the lever was pulled and discharged more gas. Simple and not many problems. The trucks could run on either gasoline or natural gas. The oil stayed very clean especially on the propane truck, its oil always looked new . The city later quit using the hybrid setup as the trucks were replaced with fuel injected trucks.
Not directly related to Electric-Propane but some history.. maybe.
maybe there's a benefit to converting a diesel generator to propane, then, so i could use some biodiesel fuel along with propane depending on availability.
i live in michigan, so fruit for a still would be difficult to keep around in the winter.
Well said!!For many all electric is not viable either. So we must all pick and choose according to our needs.
Pete : )
Only non-diesel engines could be 100% converted, but I believe if you set it up to run on propane it would probably run just as well on NG. I can'tyeah, i'm reading that about max 5% can be augmented to an existing diesel fuel system. maybe it'd be better to do gas/e-85/propane generator and then retrofit to a dc lead setup.
i really like multiple fuel options. can a set-up that is converted for propane, run on NG as well? what's the difference there?
