Google probably hasn't helped because you generally can't find answers to questions that aren't usually relevant to ask. It's not in a spec because it's not really relevant.
Voltage ripple, I mean, infinite, I guess.
You could feed it half-wave rectified AC and it would be fine. The battery would just only charge during the parts of the cycle that are above the battery's voltage level. I.E. If the batteries were "full" at 42 volts, and you're feeding it 40 volts that spikes up to 42v every 100th cycle, it's going to take 100x as long for the battery to reach 42v than it would have if you fed it flat 42vdc.
Just note that the batteries will charge to the peak that they're given (even if at a slower rate), so if you feed them 41vdc with a 3v ripple, you'll be overcharging your batteries to 41+3=44v instead of 42.
As to current ripple, well, current will just mirror voltage.
You can think of a battery as a big slow capacitor I suppose, voltage curve aside. It will soak up nearly bottomless current nearly instantly if all you're building is a 10a charger.
Discharge works the same. You might demand energy from the battery in all kinds of wonky manners, it doesn't care if the current wanders all over the map.
