You can't beat a series wound DC motor for pure low-rpm torque. On the other hand, AC motors can run at very high rpm and geared down to make torque. There's pros and cons for either. The DC motor is usually cheaper and easier to control. The AC motor has a much more complex controller adding to the cost. DC motors have brushes and a commutator to wear out. The AC does not. I think DC motors even sound better. =)
If one style of motor had any serious advantage over another we wouldn't have a choice. An example of this would be PM motors. It's not very cost effective to make a 13" PM motor for use in an EV. That's why we have series wound and AC motors. AC motors are begining to gain popularity as the "technology" comes down in price. Their already replacing series wound motors in golfcarts.
If I could afford it I'd be using AC. I think it has more advantages. Higher voltage being one of them. I can't fit 20+ lead acid batteries on a motorcycle chassis or afford lions so I'm using a series wound.
