Hi:
I'm just getting started with my EV conversion project and while I await the arrival of my donor car, I wanted to pick some brains here if that's possible about mounting the Tesla LDU.
I suspect I will be running into a similar issue that other mid-engine conversions encounter and that's with the LDU not fitting in the stock position of having the motors aft of axle insertion point. Instead, I will need to mount the LDU backwards and upside down with the motors closer to the front of the car (because of suspension issues).
Q: If the external oil pump is the way to go, what specs should I look for besides the obvious (12V, continuous duty)? I know there are lots of off-brands for all the kids throwing turbos on NA cars on a budget and needing scavenge pumps but will something like this offer sufficient pressure/flow rate?
threepedals.com
Also, what's the proper flow (pump -> LDU -> cooler -> reservoir -> pump)?
Q: How do other people solve this issue?
Thanks in advance for your posts.
- I looked in this forum and found some folks talking about using a model 3 motor instead, or making changes to a Tesla SDU, but nothing LDU specific.
- I KNOW this works because ECC in the UK have done several Ferrari 308 conversions with a similar problem. Ive asked them to see if they would be willing to share a few more details but it does sound like at a minimum, they used an external oil pump. I'm hoping these folks will be willing to answer some of my questions (esp since i'm geographically unable to be a customer of theirs) but just in case they dont, I wanted to open up a thread here.
Tilton Electric Gear Oil Pump - Oil and Coolant Continuous Duty - Three Pedals
Oil and coolant rated pump, continuous duty – perfect for racers for transmission and differential cooling Continuous duty pumps are designed for applications where the pumps needs to operate continuously for longer than two hours at a time without cool down. Available separately – intermittent...
