I already have an email out to a CV axle mfg but I haven't heard back yet; work has gotten in the way of me sending out some more. In the meantime, I wanted to see if you folks might have some ideas on what's the maximum angle I can expect out of some CV axles and still have them live? I have experience tearing axle boots and destroying axles at max drop when offroad racing so I know there's such a thing as "too much" for a given application. This car won't be going over whoops BUT I do want to confirm that this is viable before cutting any subframe bits.
Here's the math I've done so far.
I can move the motor forward an 1-2" (horizontal plane) by cutting off some frame mounting points which need to be relocated anyway.
That would reduce the angle to 16.254 degrees
Q: Is this too much?
My internet searching says that <20 degrees should be good enough but I just wanted to double check.
FWIW, the EV motor makes 435HP and the equivalent amount of torque.
- The distance between the LDU and the spindle is 20"
- At max drop (coilover suspension unloaded so the equivalent of the Telsa mid jump), the offset in the horizontal plane is 6.5"
- At max drop, the offset in the vertical plan is 3"
- By my math the max offset is the angle between 20" and the hypotenuse of 6.5" and 3" (7.16").
