Good evening,
I am attempting to build an electric motorcycle and I found the QS138 motors which seem fairly popular with lots of builds online using them.
I did however notice there are 3 different versions with different ratings online and I wanted to know if there was anything on the variations that I am not seeing. They appear to just be different wattages with basically the same top speed. The version 3 model also appears to have an integrated gearbox for a little bit of reduction.
Is there some reason that the 3000 watt rated and the 6000 watt rated models both have the same climbing grade (what a dumb stat) and top speed? The version 1 is the higher wattage one so it might make sense that its less efficient but a 100% increase in efficiency is not logical.
Here are the links I am looking at they appear to be a real subsidiary of the manufacturer as far as I can tell so you would expect their information to be accurate. There is a lot more information in graphs and stuff I can't read because of Chinese legends.
v1 - 578.0US $ |QS Motor 138 70H V1 72V 100KPH 6000W Continous 10kw Peak Sprocket Mid Drive Motor Powertrain Motor Kits for Electric Dirt Bike|Motors| - AliExpress
v2 - 578.0US $ |QS Motor 3000W Electric Motor 5000W 138 72V 100KPH New V2 Mid Drive Motor Powertrain Motor Kits for Adult Electric Motorcycle|Motors| - AliExpress
v3 (doesn't have a combo for some reason) - 319.0US $ |New Arrival QS138 70H V3 72V 100kmph Mid Drive Motor with 1:2.35 gearbox for Electric ATV Dirtbike Motorcycle|Motors| - AliExpress
I am very new to motor sizing and banging my head against a very complicated subject of power, efficiency, weight, longevity, and type. Thanks for any help!
LarryM
LarryM
