Question bridge H in controller Curtis 1244
874 Views 7 Replies 4 Participants Last post by  marcelo2112
Hello everyone, I am repairing a curtis 1244, I see that it has an H bridge to feed the motor rotor.
If the positive of the battery goes directly to the motor, why does it require a bridge h? Greetings and thanks.
1 - 8 of 8 Posts
Perfect, but why half a bridge in the rotor? To brake? I am changing mosfet and wanted to save me some of the half bridge high side, will it work? Thank you.
You need at least two switches. What I call a quarter bridge consist of a gated switch like a mosfet for the chopper and a diode for freewheeling giving single quadrant operation. A half bridge uses two gated switches (mosfets) with synchronous rectification and gets regenerative capability for two quadrant operation. The full H bridge is needed for 4 quadrant operation.
major
I ask the experts, what is the circuit that closes the main contactor? I have the code 3.4, change all the lm339 but I do not understand the circuit that activates the mosfet, where does the signal that activates it come from?
1 - 8 of 8 Posts
