My car is a 1994 Saturn SC2 which now has an AC50 motor and a Curtis 1238, 3 phase controller with regenerative brakeing. The noise that I have been talking about is really that energy which we disregard as waste. Anything that is less than 100% effecient is wasting some energy. Nothing is 100% and absolutly nothing is overunity or perpetual.
I am not fully prepared to discuss the experimental circuit that I have been working with, however I can discuss the problems that reduce the performance of any motor. Any vibration will result in a loss of energy so careful balencing of the flywheel and/or linkage components will be necessary. Excessive current draw will result in the production of heat and will also rapidly discharge the batteries so careful power management is essential. When the batteries are weak the management of power becomes more difficult. Carefully consider the next four facts. 1) As current is drawn from the batteries the battery voltage will drop sharply. 2) A motor will run faster when supplied with high voltage than with low voltage. 3) A motor that is stopped or running slowly under load will draw more current than a motor that is running at its best speed and at its ideal load.
4) The faster a battery is discharged, the less is the total recoverable energy, or Perket effect.
A motor runs best when supplied with both suffcient voltage and current. Even if sufficent current is available, low voltage will cause the motor to lag. In my car, acceleration requires as much as, 500 amps but at a nice steady 60 mph cruise, current may be as little as 50 amps. As the batteries get weak the trouble is acceleration. If there were no traffic, no traffic lights, no stop signs, no sharp turns, there would be no problem; I could drive at a constant speed from point A to point B. At the car's best constant speed, the range is impressive, but in the real world, getting up to speed after each stop is a problem. The solution comes in the form of several types of regenerative systems. The most common is regenerative braking. One other that has not been widely accepted is called "Regenerative Acceleration." The inventor, Thane C. Heins, has a lengthy explanation of how it works. I frankly don't think that it does work to any great advantage, but people are trying hard to find solutions. My own approach to the problem seems to be working well for me, but I will keep on testing the car before I get too excited.
