Re: [EV] RE: 96 S10 a good candidate?
> Is this S10 a manual transmission? Manual or power brakes? Manual or
> power steering? It will be easier to get running with the manual
> options, but many on the list have found solutions for power brakes
> (electric vacuum pump) and power steering (electric pump or existing
> pump with a belt to new drive motor). The manual transmission would be
> the easiest to attach to and use, or a much larger motor driving the
> rear end directly, with a much larger controller. The manual
> transmission will allow a more reasonable priced DC motor and controller
> to be used.
Its manual transmission, but power everything else.
> Look at the EV Album and see what others have done with a small truck.
> Here is a '95 S10 on ebay that was professionally built, AC drive I
> believe.
> Check out Solectria E10: item 140142830024
> http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1401428300
> 24&ru=http%3A%2F%2Fmotors.search.ebay.com%3A80%2F%3Ffrom%3DR40%26satitle
> %3D140142830024%26fvi%3D1
nice truck
> Good luck!
thanks.
Eduardo K. | Roses are #FF0000
http://www.carfun.cl | Violets are #0000FF
http://ev.nn.cl | All my base Are belong to you
> to be used.
> believe.
nice truck
> Good luck!
thanks.
