Re: [EV] What type controller..
786 1
Phelps wrote:
> Ok.. It is time for me to look at buying a controller..
> Like I have stated before I have a Motor that takes 30 volts at 300 amps,,
> However I am planing on using 36 volts and I guess at times that would bring
> the current up to 360 amps .
> It is a air craft starter engine. My car will weight no more than 1500
> pounds when done and that's with the batteries and all..
> What are my choices for controllers that would do a good job for this??
> I am also assuming that 36 volts will be ok when I use a controller?
I am more or less in the same bandwagon and plan to buy a 72volts Alltrax.
Eduardo K. | Darwin pone las reglas.
http://www.carfun.cl | Murphy, la oportunidad.
http://ev.nn.cl |
| Yo.
1 - 2 of 2 Posts
Discussion Starter · #2 ·
Look at the ALLTRAX 7245, that is what I'm running in
my 94' Eclipse. The voltage range actually has a
90vdc limit in it's programming, so I bumped my main
battery bank voltage up to 78vdc. I also power the
field of my aircraft generator with a separate 24volt
battery pack (12 volts didn't have enough torque,
36volts kept ripping the rubber motor mounts out and
ruined a CV joint, 24volts seems to give me enough
torque at inclines, and can keep the car running
highway speeds) , therefore leaving all the main pack
juice for the armature.
Look at it at: www.texomaev.com
--- Eduardo Kaftanski <[email protected]> wrote:
> On Sun, Jul 29, 2007 at 06:45:35PM -0400, Phelps
> controller..
> all..
> use a controller?
> http://ev.nn.cl |
> | Yo.
1 - 2 of 2 Posts
