1 - 11 of 11 Posts
Re: [EVDL] 10th S10 outing/13 OUTING 127MILES
The s10 now has 127 miles on it. Yesterday I had it rolling between 100 and
105mph but it does have a lot of vibration starting at about 70mph increasing
as I go faster. The vibes go away when I am off the throttle.Tommorow I will
put it up on jack stands to see if I can see problems.I plan to take it out to
the drags this weekend but with this vibration problem only run it hard to the
1/8 mile.150 motor volts should work fine. On the street 2000 motor amps
really make the 9.2inx28in dot drag radials spin hard so I will start the
controller out at 1500ma.I am having so much fun!! Dennis Berube
Discussion Starter · #2 ·
> start the
Ouch - only 1500 milliamps <g> I know you want to be careful but...
LMAO
Paul "neon" Gooch
In a message dated 8/8/2007 5:35:02 P.M. Pacific Daylight Time,
[email protected] writes:
increasing
Dennis, check with Wayland to see what he did to fix his vibration problem,
I think I have an idea what could be wrong but check with him first.
Jim Ludiker...................still the second quickest lead acid EV (9.44
et) behind you, from seven years ago.
************************************** Get a sneak peek of the all-new AOL at
http://discover.aol.com/memed/aolcom30tour
Hopefully the vibrations are just a drive shaft issue. Whenever I have drive shaft issues though, the vibrations are worse at part throttle and go away at full throttle or at zero throttle / high rpm deceleration
Brian
I caught that too, but thought I'd be nice. 1500ma really is a little conservative though ;-P
> -----Original Message-----
> From: [email protected] [mailto:[email protected]xxx.edu]On
> Behalf Of Paul
> Sent: Wednesday, August 08, 2007 6:47 PM
> To: Electric Vehicle Discussion List
> Subject: Re: [EVDL] 10th S10 outing/13 OUTING 127MILES
> > start the
> LMAO
> Paul "neon" Gooch
In a message dated 8/8/2007 11:41:24 PM US Mountain Standard Time,
> Date:8/8/2007 11:41:24 PM US Mountain Standard Time
> From:[email protected]
> Reply-to:[email protected]
> To:[email protected]
> Received from Internet:
> >From: [email protected] [mailto:[email protected]]On
> >Behalf Of Paul
> >>start the
> >LMAO
> >Paul "neon" Gooch
Sorry folks that was suppose to be 1500 motor amps.So some really do read my
posts! Dennis
Discussion Starter · #7 ·
> do read my
> posts! Dennis
Yea! Though sometimes I think a lot of list members feel like their
posts don't even get read. I know I have felt that way at times and
at least one other list member has told me the same. I'm sure Mike
and I both knew what you meant, but "ma" has such a common meaning!
Thanx for the chuckle (picture in your minds eye *Dennis* "launching"
on 1 1/2 amps - and the crowd falls asleep :)
Paul
In a message dated 8/9/2007 6:20:13 P.M. Pacific Daylight Time, [email protected]
writes:
________________________________________________________
Yea, when Lee and the big boys get on here I just sit back and
listen.....eyes open mouth shut.
Jim L
_________________________________________________________
Discussion Starter · #9 ·
How about that old trick of disconnecting the driveshaft and rotating
it 180 degrees and reinstalling to see if the vibration goes away?
Did you have it high speed balanced when it was made? What rpm did
they spin test it up too? Maybe you already bent it? ;)
Does it have any sort of balance weight attached to it? Is it still attached?
I had to go to an aluminum driveshaft to get rid of a similar vibration in my gasser (which was Chevy's TSB fix, balancing made it worse). The problem started around 75 mph. I have been up to 130+ mph on the Salt Flats and race track now with no problems.
----- Original Message ----
To: Electric Vehicle Discussion List <[email protected]>
Sent: Thursday, August 16, 2007 8:21:54 PM
Park yourself in front of a world of choices in alternative vehicles. Visit the Yahoo! Auto Green Center.
http://autos.yahoo.com/green_center/
Discussion Starter · #11 ·
> gasser . (which was Chevy's TSB fix, balancing made it worse).
I put 4.10 gears in a vehicle and the stock steel driveshaft which
previously had no vibration; had one with the increase in shaft rpm
going from 2.73 gears to 4.10's at highway speeds. A switch to a
lighter weight aluminum shaft made the vibration go away.
Are you running a Mark Williams driveshaft Dennis? What's it made of?
What's the maker of the shaft say about the vibration?
Is your Armature balanced extremely well? Up to what rpm?
1 - 11 of 11 Posts
