1 - 1 of 1 Posts
Re: [EVDL] 9" adv Aluminum feild coil housing ?
Jeff,
Sounds like I have to look elsewheres for more
weight!
Thanks,
Jeff McCabe
--- Jeff Major <[email protected]> wrote:
> Hi Jeff,
> Yeah, you could make the housing out of aluminum,
> but
> your motor would be crap. The housing or frame or
> yoke is an important part of the magnetic circuit,
> called the back iron. It needs to be ferrous
> material. And I suspect, your motor has a rolled
> steel frame, not cast iron. Even AC motors, which
> often have an aluminum housing, have steel stators
> with back iron inside. So that heavy motor housing
> is
> not "useless weight".
> Regards,
> Jeff M
> --- Jeff Mccabe <[email protected]> wrote:
> > In my ever searching quest to ride my Ev of
> useless
> > weight.Is it possible to make the field coil
> housing
> > which is cast iron now, out of billet aluminum?.
> Jim
> > yours ears on out their.
> > I searched the archives and didn't find any hits
> on
> > the idea.
> > I have both NC milling equipment at my disposal
> and
> > a
> > large engine lathe that I would use?
> > Thanks, Jeff McCabe
> > http://www.austinev.org/evalbum/736
> > _______________________________________________
> > For subscription options, see
> > http://lists.sjsu.edu/mailman/listinfo/ev
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam
> protection around
> http://mail.yahoo.com
1 - 1 of 1 Posts
