Re: [EVDL] Battery Revival
On 11 Feb 2011 at 22:33, [email protected] wrote:
> I mixed EDTA in distilled water ... started charging the batteries
> individually ... I drove it ... then charged again ... 4 times ... then
> 3 times ... After that, I started driving it to work ... The batteries
> had enough capacity for me to drive 6-8 miles ...
This is an old Home Power trick. As I understand it, the EDTA is supposed
to bind to the lead sulfate. It can't turn it back into elemental lead and
restore it to the active material in the grids, however.
Next time it might be interesting to try an experiment. Try the charging
regimen you describe without adding the EDTA on half the batteries. Use
EDTA on the other half.
My guess is that most of the benefit from this system results from the
charging and repeated cycling. "Exercising" a battery will always increase
its capacity, even when it's just about ruined (as yours were).
EVDL Administrator
Note: mail sent to "evpost" and "etpost" addresses will not
