Re: [EVDL] Broken motor advertised as "New" on ev tradin post
I called and left voicemail about him needing to update or retract the ad
before I emailed EV list. He may have accidently uploaded the wrong
picture...if so, hopefully he'll get it updated so he doesn't get a bad rep.
I'm sure he's not trying to scam, otherwise he'd found a good picture online
and photoshopped it a little for use on the tradin post.
----- Original Message -----
To: "Electric Vehicle Discussion List" <[email protected]>
Sent: Tuesday, October 30, 2007 10:26 PM
Subject: Re: [EVDL] Broken motor advertised as "New" on ev tradin post
> Jim is a great guy, I'd trust that if he fixed it, its in good running
> order. He stands by his work.
Ben <[email protected]> wrote:
>> Actually, I hit Google to get more details on the model, and found this:
>> http://electricmotorcycles.net/modules/weblog/details.php?blog_id=88
>> Key part -
>> "It arrived damaged
>> The guys at thunderstruck-ev were very cooperative, and arranged to
>> have the motor shipped down to Portland, where Jim from hi-torque
>> electric replaced the cracked rear bell and checked out the commutor
>> and brushes, and shipped it back. I'm now waiting for it."
>> Accompanied by the same picture seen on EVAlbum. So, I would assume
>> the sale is of the Jim Husted-repaired motor, not the damaged one.
>> Ben
>> On 10/30/07, Bruce Weisenberger <[email protected]> wrote:
>> > While not a motor expert. I'd pass on it. You have no idea of the
>> > internal
>> > damage to the commutator or shaft. Also not knowing what caused that
>> > to
>> > collapse could have caused secondary damage or internal shorting or
>> > torn
>> > open wires.
>> > On 10/30/07, Alan Brinkman <[email protected]> wrote:
>> > > Ben,
>> > > Get the model number of the motor and E-mail Advanced DC and see what
>> > > a
>> > > new end-cap would cost. Add in some time or cost to get it changed
>> > > out
>> > > and you have an idea of what you think it is worth. From my one
>> > > to Advanced DC I received a motor outline drawing and performance
>> > > curve.
>> > > They seem helpful. If the motor needs a headband (screen over the
>> > > brush
>> > > holders) to keep out debris, you can order that at the same time.
>> > > Good luck.
>> > > Alan Brinkman
>> > > -----Original Message-----
>> > > From: [email protected] [mailto:[email protected]] On
>> > > Behalf Of Ben
>> > > Sent: Tuesday, October 30, 2007 4:25 PM
>> > > To: Electric Vehicle Discussion List
>> > > post
>> > > I saw that a few days ago, that's what I thought. How repairable is
>> > > that endcap (Jim?)
>> > > Considered throwing a real lowball offer at the guy.
>> > > On Oct 30, 2007 10:41 AM, Mark McCurdy <[email protected]> wrote:
>> > > http://www.austinev.org/evtradinpost/index.php?method=showdetails&list=a
>> > > dvertisement&rollid=1895&fromfromlist=classifiedscategory&fromfrommethod
>> > > =showhtmllist&fromfromid=29
>> > > > New ADC 4002 Tropica Series-wound 20HP 72V
>> > > > Picture posted clearly shows the damage on the left, power stud and
>> > > the part
>> > > > of the cap it's bolted to is smashed in. Can see where it's cracked
>> > > away
>> > > > from the end cap.
>> > > > Just a head's up because the damage isn't obvious at first.
>> > > > _______________________________________________
>> > > > For subscription options, see
>> > > > http://lists.sjsu.edu/mailman/listinfo/ev
> Travis Gintz
> 1986 Honda VFR AC conversion
> Http://blog.evfr.net/
