Re: [EVDL] Building a controller yourself
541 1
Lee,
In your explanation below, what was typically used for the shorting bar? Was it a brush? Was it a piece of copper held tightly against the bolt heads? Or was it something else?
Thanks.
Bill Dennis
Lee Hart wrote:
>The trick is that there are intermediate contacts between positions. The
>shorting bar is wide enough to short two adjacent contacts as it moves.
>The intermediate contacts have resistors in series, to always provide a
>path for the current as the switch is moved.
>Example (view with a fixed-width font like Courier):
12v__________O ||---------to motor
__/\/\__O \movable shorting bar
24v_|________O
1 - 2 of 2 Posts
Discussion Starter · #2 ·
Bill Dennis wrote:
> Lee,
> What was typically used for the shorting bar? Was it a brush?
There were several systems. The actual contacts were generally silver.
This could be silver plated copper, or a brass bolt with a silver
contact brazed onto its head.
The moving part could be built the same; if so, it would have some kind
of spring mount to allow it to shift a bit so the two contacts made good
contact. Or, the moving part could be a stack of sheet metal parts that
sweep over the contact somewhat like a squeegee on a window. Or, it
could be a carbon brush like you see for a motor controller. The
solution the designer picked depended on the power level being switched,
and how often he expected it to be moved (wear issues).
Forget the perfect offering
1 - 2 of 2 Posts
