Re: [EVDL] CHAdeMO rapid charging station in > Portland
It's 500 volts DC at 200 amps. The charger itself will provide no real regu=
lation. Some of the small pins on the connector are CAN bus communications,=
this is what will provide the control to the off board quick charger.
So in order to use one you will need a CAN enabled BMS so this will make in=
tegration in to conversions difficult if you don't have a relatively sophis=
ticated BMS. The other problem is that no SAE standard instruction set for =
CAN communications has been set to my knowledge, which is a major hindrance=
to the industry right now in my opinion and a question I've ran in to more=
than once.
Still 50KW recharge capability. I'll take it! I am on the list to get a Lea=
f, I should be able to order by Thursday and being part of the EV Project I=
have to get the fast charge port and they have many planned for the Phoeni=
x market so in about a year I'll let you know how it works if I buy the car=
. They are warning that quick charging often will hurt the pack life, espec=
ially in the heat, there is a battery temperature gauge on the dash so they=
are making us aware of this. I plan on leaving an evaporative cooler runni=
ng in my garage where the car is parked during the summer and possibly just=
using the 120vac cord if I can to slow charge it. =
Regards,
Ricky Suiter
Elite Power Solutions LLC
92 Saturn SC Conversion
> Message: 19
> Date: Mon, 27 Sep 2010 11:41:07 -0700
> From: Peter Gabrielsson <[email protected]>
> Subject: Re: [EVDL] CHAdeMO rapid charging station in
> Portland
> To: Electric Vehicle Discussion List <[email protected]>
> Message-ID:
> <[email protected]>
> Content-Type: text/plain; charset=3DISO-8859-1
> I think this is DC since the input on the leaf is for level
> 3 DC.
> On Mon, Sep 27, 2010 at 11:28 AM, shred <[email protected]>
than once.
Regards,
Ricky Suiter
> Message: 19
> Portland
> Message-ID:
> <[email protected]>
> 3 DC.
> wrote:
> > Does anyone know if the output of this charger is DC
> or AC.
> > I thought all level 3 chargers were DC (more or less)
> straight to the
> > battery pack.
> > Neal
> > | REPLYING: address your message to [email protected]
> only.
> > | Multiple-address or CCed messages may be rejected.
> > | UNSUBSCRIBE: http://www.evdl.org/help/index.html#usub
> > | OTHER HELP: http://evdl.org/help/
> > | OPTIONS: http://lists.sjsu.edu/mailman/listinfo/ev
> www.electric-lemon.com
> [email protected]
> For general EVDL support, see http://evdl.org/help/
> For subscription options, see http://lists.sjsu.edu/mailman/listinfo/ev
> End of EV Digest, Vol 38, Issue 43
