Re: [EVDL] Door handle replacemenet Jet Electrica,
Now you are getting down to where the EVDL will do you almost no good because this is a car specific problem. It is similar to a VW Rabbit in design. Even had a VW engine I think. http://www.absoluteastronomy.com/topics/Dodge_Omni The Omni and Horizon are virtually identical. The above group could get you started. I bet you find the way to fix tonight. A hint. I bet you take off the door panel and you will be able to see the inside of door bolt or nut that holds it on. Good luck. Don't forget all cars are made to be repaired. Lawrence Rhodes....
