1 - 2 of 2 Posts
Re: [EVDL] electric circuits- motor rotation
IMO I dont think you have to change rotation of your motor for a Fiero, since it is basically just a FWD transaxle sitting midship in the chassis. Everything is still the same on the ICE rotation also. Unless I am missing something I don't think you have any concerns,
Tim
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20110323/43361eee/attachment.html
Discussion Starter · #2 ·
Tim
Thanks and you are correct in that my electric motor is wired to rotate in
the proper direction for the Fiero. My concern was the way the wiring
diagram associated with the Curtis manual showed a connection between its A2
lug while other wiring diagrams showed that this lug was not used and
Les explained the reason. So I am good.
> Tim
> URL:
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20110323/8f404412/attachment.html
1 - 2 of 2 Posts
