Re: [EVDL] EV Digest, Vol 37, Issue 39
Lee et al,
The manual for my LinkPRO specifically refers to function 6.5 under
battery monitor properties: "Voltage prescaler. This function is
only important when an optional voltage prescaler is installed on the
battery monitor." It has settings for 1-1, 1-5, and 1-10.
The LinkLITE, on the other hand, does not support prescalers, which is
the main reason I went with the Pro.
-Ben
Lee Hart Wrote:
> But it also thinks the supply voltage is only 10v, so it shuts down
> (goes into "sleep" mode). They fixed this with a software
> configuration option. When you program it for the 500v prescaler, it
> displays 100v correctly, *and* won't shut down.
> The later Link-20, Link-Pro, Link-Lite, and XBM. don't have this
> prescaler option. I'm not sure what they do if the prescaler makes
> the input voltage appear to be under 10v. Has anyone tried this?
Lee et al,
-Ben
