Re: [EVDL] Failed DC Power Systems Controller 144V 400A (1200shortterm) last fixed in
Make sure to also check the drivers, as a shorted gate will take its driver
with it.
Matt
----- Original Message -----
[email protected]>
To: "Electric Vehicle Discussion List" <
[email protected]>
Sent: Monday, January 24, 2011 8:12 AM
Subject: Re: [EVDL] Failed DC Power Systems Controller 144V 400A
(1200shortterm) last fixed in 2000.
>I have inspected the Raptor. There are a number of transistors that have
> failed by blowing apart but I cannot see damage to the Mosfets. They
> measure
> correctly, high resistance and diode in reverse direction. They are sealed
> in silicone compound. I have set of circuit drawings & will attempt a
> repair myself. Will advise outcome. David
> From: "David Sharpe" <
[email protected]>
> Sent: Sunday, January 23, 2011 1:14 PM
[email protected]>
> Subject: [EVDL] Failed DC Power Systems Controller 144V 400A (1200
>> Yesterday I was at our country estate about to return to Melbourne in my
>> EV (100ks away) and set off about 10 metres & the power failed. The
>> controller had failed, not violently but there was a whiff of burnt
>> Mosfet
>> in the air. When you consider that I have been as much as 800 ks away
>> from
>> home in this car I was very lucky. The luck continued in that I keep a
>> spare car there also , an Insight & that is how I got home. The questions
>> I have for the list is 1. Is it worth fixing? 2. If so who can repair
>> it?
>> 3. If not what is the commended reliable replacement? Who is agent or
>> address to buy. David Sharpe
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL:
>> http://lists.sjsu.edu/mailman/private/ev/attachments/20110123/b137de79/attachment.html
>> _______________________________________________
>> | REPLYING: address your message to
[email protected] only.
>> | Multiple-address or CCed messages may be rejected.
>> | UNSUBSCRIBE: http://www.evdl.org/help/index.html#usub
>> | OTHER HELP: http://evdl.org/help/
>> | OPTIONS: http://lists.sjsu.edu/mailman/listinfo/ev
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 10.0.1191 / Virus Database: 1435/3398 - Release Date: 01/23/11
