--- Jim Husted <
[email protected]> wrote:
<<<<<snip>>>>>
> I'll measure the gear if needed and I can post pics
> at
> my site but it'll probably be at least tomorrow
> night
> before I can get any up.
That is great to know.
<<<<<SNIP>>>>>
> Luckily David did shut it down before cooking the
> armature and brush ring 8^) but he'll toast it up
> again if something isn't done to ease it's load a
> bit,
> let alone keeping it cooler. Blower cooling at
> minimum is needed.
I want to install an inflow blower since blowing cold
air will put more through than pulling warm air out
the other end. The only issue is that I have to be
careful to not short out the motor leads unless there
is some hi-temp plastic I can make a cowling with. I
know I need a brushless (no spark) fan since the
battery pack is near by. I also should probably draw
the air from somewhere other than over the batteries.
> Anyway glad to see you here at the list David 8^)
This is an awesome list. The energy here is much like
one of the open source software lists I belong too.
Thank you for suggesting I join.
> I've dipped your armature and prepped a lot of it
> and
> she'll be going out here soon BTW.
Yea! Now to get the gearing figured out.
David D. Nelson
[email protected]
Yahoo! oneSearch: Finally, mobile search
that gives answers, not web links.
http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC
