Re: [EVDL] HID lighting
Actually the HIDs I know take a few seconds to start getting really
bright, and like a min or two IIRC to fully complete the starting cycle.
The starting cycle must be repeated any time the power is cycled, which
is why they're difficult to use as high beams. You can't dim them by
turning them off since it takes forever to get them back on. I'm not
sure if it's healthy for them to be cycled on and off frequently either.
Danny
(-Phil-) wrote:
>HID bulbs when running are well under 100v. Typical types are around 40v.
>The strike voltage can be in the thousands though.
>All car-use HID bulbs contain Xenon which is used to get the bulb output up
>quickly. Most newer systems are usable within a few seconds, and at full
>brightness in 10-20.
>-Phil
>----- Original Message -----
>From: "Jeff Shanab" <[email protected]>
>To: <[email protected]>
>Sent: Tuesday, September 25, 2007 6:25 PM
>Subject: Re: [EVDL] LED Taillights - a money saver in gas cars? - range
>extenderin EV's? - an analysis
>>Ya know,
>> On the HID, the first thing they do is step up form 12V to 400-600VDC
>>(run voltage, 1200 strike voltage)
>> With our higher voltage packs this may increase eff just a tad.
>>Plus
>> 3000hours, 90,000 mile bulbs
>>_______________________________________________
>>For subscription options, see
>>http://lists.sjsu.edu/mailman/listinfo/ev
Danny
>-Phil
>>Ya know,
>>Plus
