1 - 1 of 1 Posts
Re: [EVDL] homemade Hummer to have turbine jet engine recharge super capacitor batter
I made the jump to helicopter or military surplus turbines from
reading the long article, and the description of him uncrating the
turbine ... Just my mental picture. He may have something like the
system you describe - one step down, just need some vaporware products
now...
Danny Miller <[email protected]> wrote:
> Not hard, there's the Capstone Microturbine with built-in genhead and
> there's one made SPECIFICALLY for HEVs.
> There were some on eBay awhile back, primarily from a city's hybrid bus
> fleet that got scrapped. Some have been sitting outdoors in scrapyards.
> In fact, I'm pretty certain this is the product he has in mind. Just a
> theory. They can be made to run on vegetable oil too.
> The Capstone has pretty good efficiency, and IIRC calculations showed it
> should get decent mpg. Kinda vague to estimate this, trying to estimate
> batt cycle and controller losses let alone where such a thing would be
> mounted. But what I saw was gains could be possible but NOT remarkable
> like doubling your mpg or anything. That's not gonna happen.
> His "supercapacitors" might be from reading EEStor's press releases
> where they projected a cap capable of carrying the drive-shaft
> equivalent of about 4.5 gal of gasoline burned in an ICE. Well yeah we
> could all do something remarkable with those, the problem's not in being
> a genius to adapt them for a vehicle app but in whether they'll ever
> exist or not.
> Danny
> Ben wrote:
> >The difficult part of his current project involves the uncharted
> >territory he's entering. The high speed turbine / generator is
> >certainly possible, and I found a few references to prototype devices,
> >but at 60,000RPM, it is a very close tolerance system. I'm not even
> >sure if there are off-the-shelf high power generators available for
> >the rated RPM he is looking for - my quick Google search didn't
> >produce anything in production. I'm sure a surplus starter generator
> >would work, but I can't imagine it is designed to produce the amount
> >of power he is hoping to produce in a few seconds runtime. Anyone fly?
> >It sounds like he's using a helicopter turbine, anyone know the
> >typical output from their starter generators?
> >The other problem with the "just bolting something up" idea is the
> >fact that these supercapacitors he says he is going to use simply
> >don't exist yet. Sure, we've had a few companies claim they are coming
> >to market, but there haven't been any demonstrations yet and people
> >who have been on this list far longer than I have chimed in just over
> >the past few days that these capacitors have been claimed before and
> >we are already well past the dates they were supposed to go to market,
> >without even seeing demonstrations of working prototypes. At the
> >moment, they are vaporware.
> >As for the DIY garage philosophy driving his past accomplishments ..
> >it sure did, but they were in a whole different ballpark. As far as
> >the articles on him are reporting, his claim to fame are a few
> >biodiesel conversions. Very respectable from an environmental
> >standpoint, but hardly cutting edge. The fact that he did what GM
> >claimed was impossible just tells us he knows his way around a diesel
> >engine, and that GM is still outspoken against most things
> >non-petroleum.
> >If I misinterpreted something in the articles out there, please
> >correct me. So far, though, I don't see him building this turbine
> >powered series hybrid running on
> >On Nov 1, 2007 4:08 PM, GWMobile <[email protected]> wrote:
> >>I think in the end just bolting something up is actualy what it takes
> >>after suffienct design and planning. This illusion that it is mystic
> >>science or beyond the capabilities of a regualr person and a small
> >>garage is exactly what he has ALREADY proven incorrect in his last cars
> >>that ALREADY perform beyond what gm said was possible.
> >>It is in fact just '"bolting it up " that is what is necessary.
> >>That's the point he proved already.
> >>On Thu, 1 Nov 2007 9:58 am, Loni wrote:
> >>>Not to dismiss his previous accomplishments, but this time I'll believe
> >>>it
> >>>when I see it. He won't just be bolting up GM parts in interesting new
> >>>ways
> >>>to build a Hybrid Hummer with a jet turbine and "supercapacitor"
> >>>batteries.
> >>>----- Original Message -----
> >>>From: "Geopilot" <[email protected]>
> >>>To: "Electric Vehicle Discussion List" <[email protected]>
> >>>Sent: Wednesday, October 31, 2007 10:29 PM
> >>>Subject: [EVDL] homemade Hummer to have turbine jet engine recharge
> >>>super
> >>>capacitor batteries, will be able to perform awesome feats of
> >>>acceleration
> >>>and power over and over again
> >>>> from http://www.dailykos.com/storyonly/2007/10/30/14161/066
> >>>> Goodwin leads me over to a red 2005 H3 Hummer that's up on jacks,
> >>>> its mechanicals removed. He aims to use the turbine to turn the Hummer
> >>>> into a tricked-out electric hybrid. Like most hybrids, it'll have two
> >>>> engines, including an electric motor. But in this case, the second
> >>>>will
> >>>> be the [jet] turbine, Goodwin's secret ingredient. Whenever the
> >>>>truck's
> >>>> juice runs low, the turbine will roar into action for a few seconds,
> >>>> powering a generator with such gusto that it'll recharge a set of
> >>>> "supercapacitor" batteries in seconds. This means the H3's electric
> >>>> motor will be able to perform awesome feats of acceleration and power
> >>>> over and over again, like a Prius on steroids. What's more, the
> >>>>turbine
> >>>> will burn biodiesel, a renewable fuel with much lower emissions than
> >>>> normal diesel; a hydrogen-injection system will then cut those low
> >>>> emissions in half. And when it's time to fill the tank, he'll be able
> >>>>to
> >>>> just pull up to the back of a diner and dump in its excess french-fry
> >>>> grease--as he does with his many other Hummers. Oh, yeah, he adds, the
> >>>> horsepower will double--from 300 to 600.
> >>>> "Conservatively," Goodwin muses, scratching his chin, "it'll get
> >>>>60
> >>>> miles to the gallon. With 2,000 foot-pounds of torque. You'll be able
> >>>>to
> >>>> smoke the tires. And it's going to be superefficient."
> >>>> He laughs. "Think about it: a 5,000-pound vehicle that gets 60
> >>>> miles to the gallon and does zero to 60 in five seconds!"
> >>>> _______________________________________________
> >>>> For subscription options, see
> >>>> http://lists.sjsu.edu/mailman/listinfo/ev
> >>www.GlobalBoiling.com for daily images about hurricanes, globalwarming
> >>and the melting poles.
> >>www.ElectricQuakes.com daily solar and earthquake images.
1 - 1 of 1 Posts
