Re: [EVDL] Hyperbole from "Infrastructure Industry"
520 0
Yeah, you can argue that. Though, at least it is fairly open and much
easier/cheaper to implement than J1773 (inductive).
It does make plugging in your car a safer and friendlier experience,
and standardizes on a plug so maybe in the future you don't have to
carry a pile of adapters.
Also, if there is profit in installing EVSEs there will be more
pressure to have them installed everywhere, hence more charging
opportunities.
They also enable added features like remote monitoring and control,
networking, smart grid etc.
It's not all bad.
Dennis Miles <[email protected]> wrote:
> EVDL Members, Am I not correct? Isn't "J1772" mostly a scheme to generate
> billions from the Ignorant EV buying Sheeple?
> If the driver/owner of a $250,000 RV Bus can plug in to [email protected], w=
hy
> can not you or I ???
> *Infrastructure, and Range Anxiety are both HYPERBOLE!***
> Recharging or "charging stations" or "Special Charging Outlets" a=
re
> just so much HYPE!
> For every fuel retailer today there are about 9,000 electric outl=
ets
> suitable for recharging a car.
> That is not even counting the hundred or so high-powered outlets =
near
> every Interstate Highway rural and suburban interchange, (In the RV
> Campground.)
> A "Special" outlet is not necessary, just an adapter to allow one=
to
> plug in to a common outlet, 125Volts for a 6 hour charge, and 240 Volt=
s for
> "Quick" charge of 15 min to a half hour. [As in a standard home 240 Volts
> clothes dryer outlet.]
> There are 10,000 Electrics on the road today in the USA, that use=
those
> outlets. And another 30 million RVs who use the RV campground outlets. Are
> we all likely to be electrocuted tomorrow? I think NOT !
> Chevy has said that an adapter would be included with each "Leaf"=
to
> allow charging with 125 Volts home outlet. Why, then do I need a $3,000
> outlet in my garage?
> Simple answer is I don't. And several Web companies are already s=
elling
> adapters.
> At my Electric Car Repair school, that is one small lesson, we te=
ach
> it, as part of Repairing Electric Vehicles, see us at
> *WWW.E-V-T-I-Inc.com* There are Alternatives !
> Regards,
> Dennis Lee Miles
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20100915/849d36=
b9/attachment.html
> | REPLYING: address your message to [email protected] only.
www.electric-lemon.com
