Re: [EVDL] Isolate 48V from traction pack
640 0
Michaela Merz wrote:
> Hello,
> I need isolated 48 V / 10 A from my traction pack (144V). How hard is it
> to develop a dc-dc converter that would achieve that? Or is there any
> other way?
48v is a common voltage in the Telco (telephone) industry, so there are
many off-the-shelf power supplies that deliver this voltage.
A 144v pack is a little low, but most switching supplies designed for
120vac will work acceptably on 144vdc. You just have to be sure you get
one that does not use a voltage doubler on the input, as these won't
work on DC. Supplies with a voltage doubler are usually marked
"120/240vac" and have a jumper or switch or something to switch between
voltages.
Forget the perfect offering
