Re: [EVDL] It is time to raise the bar, to more "Sophisticated" Conversions !
My 39 battery, 64 mile range number was based on the volume defined by my motor's high point, firewall, fender to fender (my motor almost touches), and includes the radiator. Height might have been tight, but 26 batteries 42 miles range certainly would fit with ease.
This should hold for any Chevy 350 V8. How far you could go beyond would vary car to car. The Camaro is a very tight packaging of the Chevy V8, so it's a good test case. Note you could still cram more batteries down low. either side and ahead of the electric motor, but I figured that's where the controller, charger, and DC-DC would go.
On Fri Nov 5th, 2010 4:44 AM MDT Cory Cross wrote:
>Hey David,
>> Look under the hood of a muscle car, Chevy V8 motors are huge! Check out how
>> cavernous the motor compartment is on this diyelectriccar thread:
>> http://www.diyelectriccar.com/forums/showthread.php/electric-camaro-26006.html?highlight=Camaro
>> I just measured under the hood of my gas car, with a Chevy V8. You could get a
>> block of 27 inches x 38 inches x about 12 inches above where an electric motor
>> would be,
>I interpreted your previous statement as saying there would be one and
>only one drop-in kit that would be identical for replacing any car using
>that engine. If so, I assert you couldn't rely on any more space then
>the engine itself takes up, even if your car has more room. Thus, my
>claim of short range since everything would be within the volume of the V8.
>Now I think I understand you as saying the kit builder would have more
>than one design, but it would still be a monolithic piece that could be
>dropped in. Am I right this time?
>Cory
>_______________________________________________
>| REPLYING: address your message to [email protected] only.
>| Multiple-address or CCed messages may be rejected.
>| UNSUBSCRIBE: http://www.evdl.org/help/index.html#usub
>| OTHER HELP: http://evdl.org/help/
>| OPTIONS: http://lists.sjsu.edu/mailman/listinfo/ev
