Re: [EVDL] j1772 necessity revisited, "Conspiracy against new EVs?
444 Views 0 Replies 1 Participant Last post by  EVDL List
Douglas A. Stansfield wrote:
> Willie,
> You are going to seriously want 240v charging with the Leaf pack. Charging
> up after a long run in that car will set you back a long time at 120v
> charging.
> http://evalbum.com/2314
My Hyundai has a larger pack and more range than the Leaf. I can
easily "make do" with my 110v/220v 1500 watt Elcon charger (that should
be about the same as Leaf "L1" charging) though I can add additional
charging when needed.
Though I expect "L1" only charging will be short term, under no
circumstances will I be paying $2K+ for a semi-smart extension cord.
Willie, ONWARD! Through the fog!
http://counter.li.org Linux registered user #228836 since 1995
Debian3.1/GNU/Linux system uptime 70 days 15 hours 00 minutes
1 - 1 of 1 Posts
1 - 1 of 1 Posts
