1 - 1 of 1 Posts
Re: [EVDL] j1772 necessity revisited, "Conspiracy against new EVs?
NEC are actually only "recommended" Guidlines much as the J1772. Many
municipalities are allowed to and will deviate from those codes if they are
stupid.
For home charging in your garage there 'should' be no problem plugging into
a GFCI NEMA 14-50 installed in your garage.
mike
Bill Dube <[email protected]> wrote:
> You can actually blame GM and Hughes. The inventors of the
> MagnaCharge inductive charging system used on the EV1.
> They managed to get on the board that revises the National Electrical
> Code rules back in the mid 90's. They wrote Article 625 in a way to
> make conductive charging as difficult and expensive as possible. I
> complained loudly and bitterly, but with no effect.
> There are key phrases in Article 625 that make conductive
> charging really expensive, without actually looking like that was the
> goal. Here are two of the worst/best:
> 1) "Parts made live must be covered" when the connector is disconnected.
> 2) "Locking connector" is required to prevent inadvertent disconnection.
> 1) "Parts made live" is not the same as "live parts". Also,
> "covered" is not the same as "inaccessible" or "protected from
> accidental contact" or "Live parts not exposed." A normal connector
> is required to prevent accidental contact with the live high voltage
> parts after you disconnect it. The EV connector must "cover" _all_
> contacts that were ever live. Even if they are intrinsically dead
> when the connector comes apart, and even if they only have 5 volts
> and are harmless. This makes the connector really complicated and
> expensive.
> 2) The NEC exists to regulate for safety, not for convenience. Making
> the connector locking on a vehicle reduces safety. The connector
> should simply pull apart safely if the vehicle rolls away (or is
> towed away or driven away, or is hit by another vehicle.) Making it a
> locking connector adds the requirement of a cord strain sensor and a
> contactor the is controlled by that strain sensor. The strain sensor
> won't prevent damage to the structure wiring or the car wiring. Thus,
> when the car is towed away, live wires are likely to be exposed as
> the charger rips off the wall or the inlet rips out of the car.
> Article 625 forbids the use of an ordinary connector to
> charge the car. It is required to be different than all other
> connectors. This makes no sense, unless you are trying to make i
> expensive and difficult to charge an EV.
> To top all this off, the NEC is _not_ allowed to regulate
> what is plugged in. It is only allowed to regulate what is attached
> to a building or structure that is occupied. An outside plug next to
> a parking place is the same no matter what is parked there, at least
> that is the how the NEC is supposed to act according to the laws that
> govern it.
> The smart thing to do is to lobby your state or municipality
> to exclude Article 625 entirely. (They typically exclude parts of
> Art. 625 and well as other specific parts of the NEC.)
> Bill D.
> At 02:27 PM 11/21/2010, you wrote:
> >Agree 100%, I been saying all along.
> >It is ludicrous to have to pay for a $3000 extension cord that has a diode
> >and a resistor in it.
> >The "Charge Port" smarts necessary can be run with a $3 PIC..
> >Mike
> >On Sun, Nov 21, 2010 at 12:49 PM, Dennis Miles <[email protected]> wrote:
> > > Would you buy an appliance if an outlet costing 15% of the price was
> > > required to plug it in?
> > > Price Gouging in the USA is highly frowned upon and in times of
> Emergency
> > > is
> > > often illegal. We arrested and fined individuals after Hurricane Andrew
> in
> > > Miami and Katrina in New Orleans for selling portable electric
> generators
> > > for premium prices of two to ten times the usual.
> > > Why then are we allowing dozens of firms all over the USA to charge the
> > > American Public *twenty times the usual price* for an electric outlet
> and
> > > installing it in their garage? Requiring citizens to waste $2,750 more
> than
> > > necessary.
> > > What am I talking about? The so called "Charging Stations" being
> installed
> > > in the homes of every individual who wants to buy a "Plug-In "electric
> > > vehicle. An Electric or Hybrid Plug-In Vehicle is required to have a
> > > "Specialized Outlet" to connect the charging unit actually located in
> the
> > > Vehicle. WHY ?
> > > In every home laundry area are two outlets, one is for the Washer it is
> 120
> > > v. @ 15 a. and there are dozens of outlets all around your home just
> like
> > > that (Stated simply, If you can plug in a Toaster, you can usually plug
> in
> > > an EV.)The other one is for the Electric Dryer it is 208 to 240 v. @ 30
> a.
> > > If
> > > you own a Recreational Camper those come with a cord that plugs right
> in to
> > > one or the other, but if you get a new Electric Vehicle, you must buy a
> > > $3,000 socket and cord set and pay an additional $1,000 TO $2,000 to
> have
> > > it
> > > installed. However to add an additional Dryer Outlet only costs about
> $250
> > > including the parts needed.
> > > Why then does an EV need a $5,000 outlet? Because, the Underwriter's
> > > Laboratory said it? That is not reasonable. The only justification is
> > > Safety, but I can plug a $300,000 RV bus into a "Dryer Outlet" and the
> > > 10,000 plug-in vehicles in the USA today can plug into a "dryer outlet"
> or
> > > a
> > > "Standard home outlet" So that argument is unsubstantiated. If there
> is
> > > concern to have a "Ground Fault" protection, build it into the car.
> That is
> > > the proven method with Recreational Vehicles like Motor-homes.
> > > IMHO, the j1772 connection is inhibiting the public adoption of
> Electric
> > > "Plug-In" Vehicles. I ask "Why should we pay to have data collected
> > > regarding our habits? Let the utilities pay , Why should we pay for
> this
> > > Data collection so the "Charging Station" companies can then SELL the
> data
> > > to the electric Utilities? The Idea does not sit well with me. Do you
> Like
> > > it ? ? ?
> > > Regards,
> > > *Dennis Lee Miles* (Director) *E.V.T.I. inc*.
> > > *www.E-V-T-I-Inc.COM <http://www.e-v-t-i-inc.com/> *(Adviser)*
> > > EVTI-EVAEducation Chapter
> > > Phone (813) ID4 - E V T I or (813) 434 - 3884
> > > -------------- next part --------------
> > > An HTML attachment was scrubbed...
> > > URL:
> http://lists.sjsu.edu/mailman/private/ev/attachments/20101121/d4b8e81e/attachment.html
> > > _______________________________________________
> > > | REPLYING: address your message to [email protected] only.
> > > | Multiple-address or CCed messages may be rejected.
> > > | UNSUBSCRIBE: http://www.evdl.org/help/index.html#usub
> > > | OTHER HELP: http://evdl.org/help/
> > > | OPTIONS: http://lists.sjsu.edu/mailman/listinfo/ev
> >URL:
> http://lists.sjsu.edu/mailman/private/ev/attachments/20101121/03f0f3f4/attachment.html
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20101121/5199c7e1/attachment.html
1 - 1 of 1 Posts
