David Nelson wrote:
> If there is someone near Kelso, WA with a car that uses the 1157 bulb
> it might be a better comparison to install the LED in one tail light
> and leave the other tail light as is. I would only be testing this in
> my Gizmo tail light which looks like one from a motorcycle.
> On 9/26/07, David Nelson <
[email protected]> wrote:
>> Since I have the exact bulb you are referring to should I try to get
>> pictures of an incandescent bulb and the 3W LED in the same tail
>> light? I guess I could set the camera at the same settings to make a
>> fair comparison. Remember that the lumen spec on this red led only
>> will see that particular wavelength whereas the lumen spec on a
>> regular bulb will include all wavelengths in a broader spectrum.
