Re: [EVDL] LED Taillights - a money saver in gas cars? - >rangeextenderin EV's? - an
The PC supply I'm looking at here does 25 amps at 12 volts (300 watts), and
it's better than average. I don't know what it would take to raise the
voltage, control overcharging, and make it run off of a DC input. Maybe it
could supplement the aux battery, maybe with the addition of some alternator
regen during deceleration, to the point a large DC/DC is not required.
Might be able to find a 12 volt only "brick" type supply surplus someplace.
Marty
----- Original Message -----
To: "Electric Vehicle Discussion List" <[email protected]>
Sent: Wednesday, September 26, 2007 8:53 AM
Subject: Re: [EVDL] LED Taillights - a money saver in gas cars? -
>rangeextenderin EV's? - an analysis PC Power Supply
> down from 530 watts to 440 watts...
> Now we're talking about "pc power supply" range for $50 bucks, rather than
> expensive $250+ DC/DC converters...
> What do you folks think?
> Has anyone used a cheap pc-power supply rather than a DC/DC converter - to
> recharge their 12-volt aux battery?
> Do you think it would hold up?
> Ed Cooley
> "Adrian DeLeon" <[email protected]>
> Sent by: [email protected]
> 09/25/2007 23:37
> Please respond to
> Electric Vehicle Discussion List <[email protected]>
> To
> [email protected]
> cc
> Subject
> EV's? - an analysis
> Around and around we go...
> The one big plus for LED lighting is the possibility of using a
> smaller/less expensive DC/DC converter.
> Headlight on HI = 130W
> Heater fan HI = 250W
> Misc 12V = 60W
> TOTAL SO FAR = 440W
> 4 marker lights = 5W x 4 = 20W
> 4 turn signals = 27W x 4 = 100W (intermittent - can use "peak power" from
> DC/DC)
> 2 brake lights = 27W x 2 = 50W
> 2 tail lights = 5W x 2 = 10W
> Center brake light = 5W = 2 = 10W
> TOTAL LIGHTING = 90W/190W (intermittent)
> So LEDs can reduce your DC/DC requirements from 530W to 450W.
> Adrian
Marty
> Ed Cooley
> 09/25/2007 23:37
> Please respond to
> To
> [email protected]
> cc
> Subject
> EV's? - an analysis
> Misc 12V = 60W
> TOTAL SO FAR = 440W
> DC/DC)
> Adrian
