Re: [EVDL] Legal on lights!! How to dim LED turn signal indicators
Hi Danny and All,
----- Original Message Follows -----
To: Electric Vehicle Discussion List <[email protected]>
Subject: Re: [EVDL] How to dim LED turn signal indicators
Date: Sun, 07 Oct 2007 15:18:14 -0500
>Green turn signals??
>Not legal anywhere in the USA as far as I know. If it were
>legal, you'd be seeing teenagers mod this left and right.
>Many locales have even fought the purple button on the
>taillight to "violet" them a bit with some frequent
>ticketing.
One company, APC, recently went bankrupt because
they sold Fed DOT unapproved head and clear taillights and
fined them close to $1mill!!
While you can add lights you need to have one DOT
legal set.
Which for me is a pain as I can't find smaller
headlights that are approved at a reasonable price that are
more aero.
The big things are taillights, side/turn lights
need to reflect light when not on to fed spec's. Headlights
must have the correct light pattern to avoid blinding
oncoming vehicle drivers.
So you need to put DOT lenses at least over LED,
ect homemade lights on road vehicles.
Jerry Dycus
>Danny
Hi Danny and All,
>ticketing.
legal set.
more aero.
Jerry Dycus
>Danny
>David Nelson wrote:
>>I have a Gizmo EV which uses green LEDs for the turn
>>signal indicators. The brightness is perfect for daytime
>>driving but they are extremely blinding at night. What
>>would be a relatively simple way to dim them for night
>>use? Would a resistor in the line do it? If so, I could
>then hook up a switch which could short across the resistor
>>for daytime use. The blinkers are run by a smart-blink
>>system which I think is used on motor-cycles and/or
>>mopeds. I also believe these are on the 12V side of my
>>DC-DC converter.
>_______________________________________________
>For subscription options, see
>http://lists.sjsu.edu/mailman/listinfo/ev
