1 - 1 of 1 Posts
Re: [EVDL] li magnanesse battery AND their drawbacks..
Traditionally LiMn cells have had quite poor cycle stability. Around 500
real life cycles compared to LiCo 1000 with same cycling profile. It is
nicely cheaper to make compared to LiCo but the LiFePO4 took that cake
already. It is just so dirty cheap that Manganese cells got ran over.
Also there has been issues with Manganese cells with thermal stability.
Lifetime is dramatically reduced on high temperatures (50-80 C).
LiCo cells are a bit easier to ignited than LiMn ones. But the
difference is quite marginal. Also the energy amount in the weight is
about 20 % better on LiCo.
I've seen some new innovations on LiMn during visits in China. Prices
thou have been outrageous. So I bet on two other horses. LiCo for energy
dense systems and LiFePO4 for large commerzial sedan tupe vehicle fleets.
-Jukka
Randall kirjoitti:
> Seems kinda expensive for a higher voltage system:
> Power 26-77 UI (User installation) LIMA high-performance battery
> capacity: 1,994 Wh,
> rated power: 25.9 V,
> charge: 77 Ah,
> weight: 40 lbs,
> connection with other Torqeedo Power batteries limited to 2 batteries for
> serial connection and to 4 batteries in total.
> $ 3,599.00
> Torqeedo Power 26-77 battery block General data
> Capacity: 2.0 kWh
> Charge: 77 Ah
> Rated voltage: 25.9 V
> Final charge voltage: 29.4 V
> Weight: 40 lbs
> Dimensions (length x width x height): 20 x 7 x 9 inches
> Electrochemical base: Lithium manganese (LIMA)
> High-current resistance
> Maximum yield: 3.1 kW
> Maximum power consumption: 120 A
> ----- Original Message -----
> From: "FRED JEANETTE MERTENS" <[email protected]>
> To: "ev" <[email protected]>
> Sent: Saturday, October 20, 2007 6:52 PM
> Subject: [EVDL] li magnanesse battery
>> check out this source of batteries .
>> http://www.torqeedo.com<http://www.torqeedo.com/>
>> what do you guys think better source than dewalt ?
>> _______________________________________________
>> For subscription options, see
>> http://lists.sjsu.edu/mailman/listinfo/ev
1 - 1 of 1 Posts
