Force of air drag times distance equals energy required
.5*Cd*A*rho*v^2*d
The lowest Cd I found for a Dodge Caravan was .35, and the lowest area
was 30 square feet.
.5*.35*30ft^2*1.3kg/m^3*(55mph)^2*150miles
25.7 kWh
Energy in 16 T-105's (using 6 hour rate even though he's at 3 hour
rate, ignoring Peukert's effect):
16*6V*205Ah
19.7 kWh
He's only 20% short! However, you have to add in rolling resistance
losses, he'll be farther behind. It would take a really deep discharge
to go 150 miles, and you'd be destroying the batteries.
That said, it was a lot closer than I expected, so if there was even a
downwards slope of a few percent, they might be able to do it.
And yeah, the magnetic shocks make sense, if you could get big enough
magnets. I don't know how they'd help range, though.
-Morgan LaMoore
.5*Cd*A*rho*v^2*d
was 30 square feet.
25.7 kWh
16*6V*205Ah
19.7 kWh
-Morgan LaMoore
