1 - 1 of 1 Posts
> it would be very much but I don't have any data to back that up. I
> know that passing them through a coil hooked up to a galvanometer
> caused a sharp needle deflection but the duration was much shorter and
I meant that the needle deflection was much shorter in duration than
using a much weaker bar magnet. It is almost like the magnet is so
strong that the fields don't stray very far and yet holding one in
your hand over a meter away from a running overhead projector caused
the magnet to vibrate.
David D. Nelson
http://www.austinev.org/evalbum/1328
1 - 1 of 1 Posts
