471 0
On 6 Oct 2007 at 22:59, Morgan LaMoore wrote:
> Energy in 16 T-105's (using 6 hour rate even though he's at 3 hour
> rate, ignoring Peukert's effect):
> 16*6V*205Ah
> 19.7 kWh
He's using T-145 batteries. But let's be realistic here and use the 3hr
rating of 188ah for them (from Uve's calculator). Now we have only 18kWh.
>.5*.35*30ft^2*1.3kg/m^3*(55mph)^2*150miles
> 25.7 kWh
I have the wrong degree for this, so I may be blowing smoke - but aren't you
mixing your units here? You have kg/m^3 but you use miles for the distance.
I can't seem to get the same figures you did; my numbers are wildly
different.
EVDL Administrator
