462 0
Morgan,
Your formula is different than the way you calculated/ which is corret?
You have some ^2 and ^3 in there you don't show in your formula.
Morgan LaMoore wrote:
> Force of air drag times distance equals energy required
> .5*Cd*A*rho*v^2*d
> The lowest Cd I found for a Dodge Caravan was .35, and the lowest area
> was 30 square feet.
> .5*.35*30ft^2*1.3kg/m^3*(55mph)^2*150miles
> 25.7 kWh
> Energy in 16 T-105's (using 6 hour rate even though he's at 3 hour
> rate, ignoring Peukert's effect):
> 16*6V*205Ah
> 19.7 kWh
> He's only 20% short! However, you have to add in rolling resistance
> losses, he'll be farther behind. It would take a really deep discharge
> to go 150 miles, and you'd be destroying the batteries.
> That said, it was a lot closer than I expected, so if there was even a
> downwards slope of a few percent, they might be able to do it.
> And yeah, the magnetic shocks make sense, if you could get big enough
> magnets. I don't know how they'd help range, though.
> -Morgan LaMoore
www.GlobalBoiling.com for daily images about hurricanes, globalwarming
and the melting poles.
www.ElectricQuakes.com daily solar and earthquake images.
