Peltiers are thermocouples. Either one is technically called a Seebeck
device when generating a voltage from a temp differential.
Thermoelectric cooling's effectiveness is not that great, and few
devices have any sense of very long-term durability. Larger devices can
make a few watts. The thermal expansion and contraction makes thermal
mounting very difficult and stresses the device. Sometimes they
delaminate in a mechanical failure, exposure to elevated temps also
degrades them and eventually causes failure. A temp regulated heat
source greated reduces that problem, but that won't happen in an ICE.
Danny
Danny
Jeff Shanab wrote:
>I thought about this many times, even before I got into EV's.
>Maybe enough to offset the usage in some energy used in an active
>suspension system. ie hitting a bump throws the wheel up, and the
>circuit begins to slow the overshoot before it impacts the body, then a
>portion of that energy is used to return the wheel to proper ride
>position faster than either gravity or the spring without overshoot.
>For that matter, I sometimes wonder why ICE cars have alternators at
>all(no I don't they are cheap, and need service.) If over 70% of the
>energy in a gallon of gas is wasted as heat, why not have a thermocouple
>battery or even peltier pile on the exhaust manifold to recharge the
>battery. This is dangerously off topic unless it could make a range
>extender trailer better than integrated ICE drive. In otherwords
>compensate for some of the excess conversions that make range extender
>trailers worse mpg than just running the gas alone.
>_______________________________________________
>For subscription options, see
>http://lists.sjsu.edu/mailman/listinfo/ev
