Re: [EVDL] New gel battery breakin. Still low.
Voltage in rest is a *unreliable* indicator of
the quality of a battery, unless it is way out of
line, like 11V instead of 13V.
The *only* way to test a battery reliably is to
test it under load, at minimum to take a voltage
reading under a serious load (like 50A or so)
and preferably to check capacity (run a known load
until the battery reaches its LVD (Low Voltage
Disconnect) threshold, typically 10.5V for a 12V
lead-acid. Measure the time and calculate the Ah
capacity, compare with the spec and you know how
good or bad the battery still is.
I used to have several batteries that charged
normally, showed more than 11V on a heavy load but
had almost no capacity, they fell from 11 to 9V
after a few minutes load, so one cell was severely
out of balance and reversed too often to allow a
decent amount of Ahs.
Note that I tested if the cell was just out of balance
or had reduced capacity by drilling a small hole =
through the top of the case into the cell interconnect
and slowly charge the one cell until it received a full
capacity worth of charge. It still behaved the same,
so the 110Ah battery was toast (5 cells with good capacity
and 1 cell with about 5Ah)
On the other hand I have a few Hawker SBS30 batteries
from 1994 (17 years old!) that still are close to their
spec, when loaded with 30A (1C load) they give about 15Ah.
Success testing,
Cor van de Water
Email:
[email protected] Private: http://www.cvandewater.com
Skype: cor_van_de_water IM:
[email protected]
-----Original Message-----
[email protected] [mailto:
[email protected]] On Behal=
f Of Lawrence Rhodes
Sent: Thursday, January 20, 2011 3:10 AM
To:
[email protected]
Subject: Re: [EVDL] New gel battery breakin. Still low.
I just checked again. I have three stinkers. 12.9, 12.94 & 12.95. =
The rest after four days sitting were 13.1 to 13.2vdc. The lowest at 12.=
9 was the new battery. Lawrence Rhodes...
[email protected] only.
