1 - 7 of 7 Posts
Re: [EVDL] Nichola Tesla, Power hanging around.
----- Original Message -----
To: "Electric Vehicle Discussion List" <[email protected]>;
<[email protected]>
Sent: Tuesday, August 21, 2007 4:12 PM
Subject: Re: [EVDL] Nichola Tesla
>I seen this done as a demostration on drag strip back either in the 60's or
>70's. They had about 3 inch copper tubing set on wood frame work that was
>on both sides of the car that ran the 1/4 mile. There was a trolley type
>spring loaded trolley pick up arms that rode on these pipes.
Hi EVerybody;
Hell! Wouldn't it be easier to string catenery above the strip? Like the
trolley buses use in SF and Vancouver? This is a prerfected system, over 100
years old, the dragsters just run trolley poles, maybe bamboo, to save
weight?You would be assured of power cutoff at the end of the strip, as
that's where the wires would end! I looked longingly at Vancouver's
stretches of long streight runs of overhead wire. BOY would the zombie GO on
600 volts! Hafta run late at night when traffic was light. Of course,
Vancouver Transit might have an issue<g>?>Freeky 200 amp "Hits" when all the
trolley buses were in bed for the night?
Steam Catapult from a junked aircraft carrier? Nah! No fun, with that a
stock Yugo would beat the Zombie.Nothin in the NEDRA or NHRA about overhead
wires, IS there?
Seeya
Bob
There was a large 3 phase 120/208 125 kw generator that was on wheels that
> supply the power to these copper busses.
> I do not remember what motor it was, but it look like one for aircraft
> starting like the one we use which was rated at 80 hp at 230/460 vac 60
> hz.
> This run was done after the Green Monster had it first run.
> Roland
> From: "keith vansickle" <[email protected]>
> To: <[email protected]>; "Electric Vehicle Discussion List"
> <[email protected]>
> Sent: Tuesday, August 21, 2007 1:45 PM
>> Well what about an inverted trolly set up where the
>> lines carring the power were stuck to the drag strip
>> and the connection was a swing arm but the vehicle was
>> still driven--like a slot car but with no slot--just
>> ideas to get power to the motor with having to lug all
>> those batteries down the strip. after all the big
>> guys in drag racing use nitro for power and destroy an
>> engine every 30 sec of run time if we are to compete
>> we have to have something like this.
>> --- Lee Hart <[email protected]> wrote:
>> > keith vansickle wrote:
>> > > How about we build a drag strip with something
>> > like this...
>> > > could it work?
>> > It could work; but just as Tesla found, broadcasting
>> > power is very
>> > inefficient. You'd be doing well to receive even 10%
>> > of the power you
>> > sent. Getting 100kw to the dragsters would require a
>> > 1 megawatt power
>> > plant!
>> > The closer you can get the sending and receiving
>> > antennas, the better
>> > the performance. All practical systems of this sort
>> > depend on very close
>> > spacing; like the coils in the road and the coils in
>> > the car being only
>> > fractions of an inch apart.
>> > I doubt that Tesla could have broadcast enough power
>> > to run his car
>> > directly, given the considerable distance between
>> > his antennas. I think
>> > it is far more likely that the broadcast power only
>> > ran his battery
>> > charger. He charged the batteries slowly, and then
>> > ran them down quickly
>> > to make the car go for a minute or two. Then he'd
>> > have to wait a
>> > significant time before it had recharged
>> > sufficiently to do it again.
>> > You could set up something equivalent to a slot car,
>> > where the cars run
>> > over a guide track that also has the coupled coils.
>> > But if you're going
>> > to do that, you might as well make it an electric
>> > train, with two rails
>> > carrying power as well as guidance to the wheels.
>> > "Never doubt that the work of a small group of
>> > thoughtful, committed
>> > citizens can change the world. Indeed, it's the only
>> > thing that ever
>> > has!" -- Margaret Mead
>> > Lee A. Hart, 814 8th Ave N, Sartell MN 56377,
>> > leeahart_at_earthlink.net
>> > _______________________________________________
>> > For subscription options, see
>> > http://lists.sjsu.edu/mailman/listinfo/ev
>> ____________________________________________________________________________________
>> Shape Yahoo! in your own image. Join our Network Research Panel today!
>> http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7
> Internal Virus Database is out-of-date.
> Checked by AVG Free Edition. Version: 7.5.476 / Virus Database:
> 269.11.15/949 - Release Date: 8/12/2007 11:03 AM
Discussion Starter · #2 ·
In a message dated 8/21/2007 10:59:36 P.M. Pacific Daylight Time,
[email protected] writes:
What you saw was EJ Potter running his
"Slot Car" powered by an Allison airplane engine driving three aircraft
starter/generators hooked to the two rails going down the track.
EJ's "goonie" would rev the engine while EJ would flip the "Circuit Breaker"
then the goonie would accelerate the slot car as fast as he thought EJ could
handle, the only way EJ could release himself was to pull the circuit
breaker if he could reach it.
For those of you who never heard of "EJ Potter", he used to run exhibition
with his 327cu. in. Corvette powered motorcycle and SMOKE the tire (car tire)
the entire 1/4 mile run.
Gosh this makes me feel old, I met EJ in the mid 60's
when we went to England to put on a show for the Military..........oh yea, and
he crashed his bike there on the last run of the last day of the tour and we
brought him and his bike home in pieces.
God, I love to reminisce.
Jim Ludiker............the old guy that used to have an electric dragster.
************************************** Get a sneak peek of the all-new AOL at
http://discover.aol.com/memed/aolcom30tour
just to throw out my own off-topic, they have power-tool drag racing,
and in the unrestricted (cheating) class someone just used a rubber band
stretched back from the finish line to the start, and that acceleration
blew away everything by a huge margin.
I will take this opportunity to plug my EV Train proposal again,
where you have locomotives running on the freeway which EVs can attach
into a train by magnetic coupling of their bumpers, and get recharged
from the regen in their wheels while being pulled along.
Jack
> From: "Roland Wiench" <[email protected]>
> <[email protected]>
> Hi EVerybody;
> wires, IS there?
> Seeya
> Bob
>>hz.
>>Roland
>><[email protected]>
>>>>like this...
>>>>>could it work?
>>>>power is very
>>>>of the power you
>>>>1 megawatt power
>>>>plant!
>>>>the car being only
>>>>to run his car
>>>>ran his battery
>>>>have to wait a
>>>>where the cars run
>>>>But if you're going
>>>>thing that ever
there is a fairly big problem with that idea...
or I should say a whole family of serious problems but one of them takes
the cake :)
can you think of what that might be?
has to do with the length of the trains...
Dan
> Jack
haha.. youd get a nice surprise when you pulled up at your house and realised youd brought the rest of the train home with you.
Sent: Wednesday, August 22, 2007 12:00 PM
Subject: Re: [EVDL] Nichola Tesla, Power hanging around.
Yeah! And providing food and drinks for all your newfound" Friends?"
Whynot have a conventional flatcar train that you drive onto, sit back and
let the train's engineer pull for you? Amtrak SHOULD expand the Auto Train
ALL over USA instead of just from VA to Fla. Amtrak has to fight for mear
survival nowadaze in Congress. With the Best Govt. Oil Money Can Buy, it
isn't easy. They want you to BUY GAS and spend! This is why we don't have
interburban electric Rys anymore. Didya know you could, with enough
patience, and nickels, ride fro m Portland ME to NYC and beyond in ELECTRIC
trolley cars?This was back about when the Titanic went down, though.In my
PDX drive I sure saw enough BNSF trains carrying trux, well, the trailers.
Sure woulda been nice to put the CAR on there and wander back to the dining
car, or big plushy coach seat. Amtrak does NOT buy their seats from the
airline seat supplyers!
Keep on training
Bob
Discussion Starter · #7 ·
In a message dated 8/22/2007 8:50:22 A.M. Pacific Daylight Time,
the cake :)
Dan
could it bee that they are using stinking diesel?
1 - 7 of 7 Posts
