Re: [EVDL] No subject. Now wind powered EV.
1016 Views 1 Reply 1 Participant Last post by  EVDL List
Oops forgot to write a subject. LR
Message: 18
Date: Sat, 19 Feb 2011 15:01:52 -0800 (PST)
Subject: [EVDL] (no subject)
To: Electric Vehicle Discussion List <[email protected]>
Message-ID: <[email protected]>
Content-Type: text/plain; charset=3Diso-8859-1
http://shopping.yahoo.com/articles/yshoppingarticles/543/wind-powered-car-s=
ets-records-in-a-3100-mile-road-test/
This is a practical self charging application.? It is not the first.? There=
was =
the English Solar Van.? But because it is so small it can charge faster usi=
ng =
the wind turbine.? Maybe faster if is was a water turbine.? You'd need a so=
urce =
of running water close by though.? Since air or better yet water are more e=
nergy =
dense this type of charger trumps solar.? However in the doldrums you're ou=
t of =
luck.? Combining the three would be great.? Lawrence Rhodes...
1 - 2 of 2 Posts
They have a 8 kWh battery and can go 250 miles,
this is an unbelievable low 32 Wh per mile, but
if you look at their vehicle then you see it is
specially built on sort of bicycle wheels...
The principle of moving under the influence of
wind was discovered long ago, not just for
sailing vessels but in other applications also.
I doubt that they are the first vehicle to cross
a continent by wind power. I expect that more than
a century ago many ships did the same feat, though
not in the same time or over the road.
Regards,
Cor van de Water
Email: [email protected] Private: http://www.cvandewater.com
Skype: cor_van_de_water IM: [email protected]
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behal=
f Of Lawrence Rhodes
Sent: Sunday, February 20, 2011 1:17 PM
To: [email protected]
Subject: Re: [EVDL] No subject. Now wind powered EV.
Message: 18
was the English Solar Van.? But because it is so small it can charge faste=
r using the wind turbine.? Maybe faster if is was a water turbine.? You'd n=
eed a source of running water close by though.? Since air or better yet wat=
er are more energy =
t of luck.? Combining the three would be great.? Lawrence Rhodes...
1 - 2 of 2 Posts
