1 - 1 of 1 Posts
Re: [EVDL] Odd that it burned completely (Was:SRJC student's Focus-conversion-EV burn
Bill, I've got no personal experience, but I'm not sure it's that
unlikely. Cars themselves are made of fairly combustible materials,
even without the gasoline.
Here's one example of a LiFePo4 fire from a few years ago:
http://www.batteryvehiclesociety.org.uk/forums/viewtopic.php?t=1825
As you can see, it's ALL burnt, and the "hottest" spot looked to be
one of the battery boxes, with the PCBs of the BMS boards burned to
dust.
This was not a high profile EV and it's in my country, which I can
tell you doesn't have any public interest either way in EVs, so this
one was pretty much guaranteed to be "natural causes" rather than
anything suspicious.
It was a cautionary tale for me because I recieved my LiFePo4 cells a
month later. I had already decided not to put BMS boards inside the
battery boxes...
Bill Dube <[email protected]> wrote:
> I find it _very_ odd that the car burned so completely. The article
> said that even all the tires burned and all that was left was scorched metal.
> TS LiFePO4 cells burn more like a mattress or a couch or perhaps a
> Duraflame log. Smoky and persistent, but not very spectacular (unlike
> metal oxide Li-Ion cells can sometimes behave.) Thus, I can't picture
> a TS LiFePO4 pack fire spreading to all the tires. Possible, but not
> very likely at all.
> As fanatical as some EV advocates are, there are anti-EV fanatics
> that can get to the point of scary. Also, there are folks that are
> angered by the success of others to the point where they do some very
> crazy things. Thus, it is not inconceivable that some unbalanced
> person purposefully torched the vehicle. This sort of thing happens.
> It does not happen often, but all it takes is one nut with a match
> and a gas can. It got national press, and that is precisely what
> motivates some of these fire-bug types
> Bill D.
> | REPLYING: address your message to [email protected] only.
1 - 1 of 1 Posts
