1 - 1 of 1 Posts
Discussion Starter #1
Re: [EVDL] "One mm per volt" Battery pack layout guidelines (was:SRJC student's Focus
Myles Twete wrote:
> Hmm...so TTL logic lines on a PCB require 5mm spacing on a bare board---is
> that what you are seriously suggesting?
> How is it that computers aren't constantly arcing between lines? Surely
> there must be a problem with the analysis.
First, arcing is not a problem below about 30v.
Second, one can assume your PC board is not dirty or wet. But with
batteries in a car, it is *likely* that they will get dirty and wet.
1 - 1 of 1 Posts
