Re: [EVDL] Overdiven 10hp AC
We say AC motor as if all AC motors are the same. Most of our
generalizations are about the ACIM, AC InductionMotor. (pssst, all
motors run on AC)
If someone can get there hands on a wound rotor slip ring AC motor in
the size we need for drag racing, well the race would be on!
ACIM motors are designed for one speed and more importantly one level
of slip. The reactance of the rotor is a compromise.
If you instead have a three phase slip ring tap on the wound rotor, you
can vary the reactance, even inject voltage to lock in syncronous. You
can get regenerate the slip energy and get 10X starting torque at less
than run amps.
I have books, but I couldn't find a good online reference. Most give
speed torque curves, but the important is when they overlay the amps on it.
http://en.wikipedia.org/wiki/Electric_motor
motors run on AC)
than run amps.
