1 - 2 of 2 Posts
Re: [EVDL] Overdriven 10hp AC
that's not true for rpm Victor. only power from torque/amps is thermal.
power through voltage (which is where higher rpm draws from) is
thermally free. lossless.
the only limiter rpm wise for the motor is mechanical. either brushes,
bearings, or break apart from centrifugal forces. as far as I undestand
so far
Dan
Victor Tikhonov wrote:
>Peter VanDerWal wrote:
>>Increasing the RPM of a motor allows it to produce more power for the same
>>weight.
>Yes, but at some point it no longer will be be *continuous*
>power we're debating. Only large mass (more thermal reserve)
>motors will allow to increase *and sustain* higher power by
>spinning faster. Light motors only allow high(er) peak power.
>Victor
Discussion Starter · #2 ·
> so far
> Dan
There will be thermal losses caused by mechanical friction; this will
increase with RPMs. Also, magnetic hysteresis losses will increase
with speed. In DC motors, though, these losses are small compared to
resistive heating.
-Morgan
1 - 2 of 2 Posts
