1 - 7 of 7 Posts
Re: [EVDL] Paging John Wayland..............Plazma Boy..........................
In a message dated 8/10/2007 2:40:55 P.M. Pacific Daylight Time,
[email protected] writes:
Jim/Dennis,
Are you guys going right from a slip yoke on the motor drive shaft to the U-
Joint on the rear-end? Or do you have an intermediate carrier bearing in
the driveline?
Mike,
Anchorage, Ak.
_____________________________________________--
One plain, non-cv, U up front, one plain U in the back with no intermediate.
************************************** Get a sneak peek of the all-new AOL at
http://discover.aol.com/memed/aolcom30tour
Discussion Starter · #2 ·
In a message dated 8/10/2007 4:21:08 P.M. Pacific Daylight Time,
The motor shaft and the pinion shaft _must_ be parallel when
you are driving the car. They don't have to be coaxial, but they
_must_ be parallel within a couple of degrees. This is both
up-and-down as well as side-to-side.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Bingo Bill, you have the right answer, I thought you only knew how to make
bikes go fast, however one slight error. The two shaft centerlines should be
parallel ALL the time when viewed from the top and the side.
Jim Ludiker.................still the quickest EV behind
Dennis..............for seven years.
In a message dated 8/11/2007 8:47:30 AM US Mountain Standard Time,
> To:[email protected]
> Received from Internet:
> The rear suspension does not move the differential perfectly up and
> down. It tilts just a bit, especially with leaf springs under severe
> acceleration. Thus, you will get some vibration at times. It is
> unavoidable with typical rear suspensions. (You can build a
> suspension that works correctly.) Thus, you set up the angles to
> minimize the vibration under typical driving conditions.
> Bill Dube'
Hi Bill,The S10 has a coil over ladder rear fully adjustable suspension.With
all the excitement of driving this new truck maybe I missed the vibration but
I will listen more close next time down the track. Dennis Berube
In a message dated 8/11/2007 8:47:58 A.M. Pacific Daylight Time,
Yes! that is why they use four bar equal length on the really hot cars.
__JIM L________________________________________________
Bill Dube'
Discussion Starter · #7 ·
In a message dated 8/11/2007 1:53:54 P.M. Pacific Daylight Time,
If it is a four-link suspension, then you will be able to set it up
perfectly.
Only if the top view of the drive shaft geometry is correct.
__Jim L______________________________________________
Congratulations on some mighty quick runs. Most folks don't do nearly
as well, even after years of work on the car.
Bill Dube'
1 - 7 of 7 Posts
