1 - 1 of 1 Posts
Re: [EVDL] Press release on Firefly "Oasis" battery
Jeff Shanab wrote:
>>Then lets throw in the cycle life difference and I think it becomes
obvious.<<
Hello Jeff,
From an article written by Noel Adams in Electrifying Times =
(http://www.electrifyingtimes.com/firefly_energy.html), where Noel is =
interviewing Mil Ovan, Senior VP Firefly Energy, Noel writes:
"The people at Firefly Battery think that they can change this. They =
have developed a battery using lead acid chemistry that significantly =
increases the power density while improving cycle life. Lead acid =
battery chemistry is theoretically capable of delivering 216.8 Whr/Kg =
while current technology averages 30 Whr/Kg.... I haven=92t been able to =
tie Mil down to a figure on energy density but he expects it to be two =
to three times the current energy density of current lead acid =
batteries. This would put them close to NiMH at 70 whr/kg but lower than =
Lithium at 120 whr/kg." Two to three times is great. That will allow me =
to use my EV as a long range commuter.
He goes on further to write: " I asked Mil about the cycle life of these =
batteries. He told me =93cycle testing is still in progress so we don=92t =
have a definitive answer right now. It takes a long time since there are =
only so many charge discharge cycles you can do in a day. We were =
expecting these batteries to perform slightly short of NiMH and Lithium =
batteries but so far we are doing better than expected, tracking very =
closely to the cycle life of NiMH=94."
While no interview date was published on the Electrifying Times page, he =
is talking about the FY2006 Defense Bill. This means an interview in the =
2005-2006 time frame. I was wondering where you were getting your cycle =
life numbers for the Firefly's? I could not find anything so far using =
Google and there is very sparse technical data on the Firefly site; just =
enough to whet the battery appetite.
The Oasis battery advertisement page from Firefly says 2x greater cycle =
life and references 200 cycles as the start of a drop off point for the =
Fireflys. But does that mean that if I can get 1,000 cycles out of my =
Optimas, does that mean I will be able to get 2,000 cycles out of a set =
of Fireflys'?
Peter
1 - 1 of 1 Posts
