Re: [EVDL] * Re: How to equalize charge Trojan T-125s?
> Got the COM port settings right. Think I got the
> USB-serial done
> right, according to Windoze Device manager, and its
> driver is loaded.
> Had a couple more things to try, but I got tired.
Bring up a terminal program, and try shorting out pins
2 and 3 on the 9 pin connector. Then whatever you
type should appear on the screen, no matter what the
baud rate is set to. If you see what you type with
pins 2 and 3 _not_ shorted, then you have local echo
turned on, and you should see what you type _twice_,
with pins 2 and 3 shorted.
- Steven Ciciora
Need a vacation? Get great deals
to amazing places on Yahoo! Travel.
http://travel.yahoo.com/
> USB-serial done
> driver is loaded.
- Steven Ciciora
